.I always consider CLASS III as IT,the person who sent back the report must have some experience to do this.
Or not
From
Parker Bell
A Class III appliance operates at less than 50v and therefore does not need to be PAT Tested. However. The lead used to charge many low voltage electrical items (like mobile phones or laptop computers) is usually a Class II appliance and should be tested as such.
( back to the top of page )
How do I make a visual inspection?
Before you begin to carry out your PAT Testing it is vital that you carry out a thorough visual inspection. You should check for the following:
* There are no cracks, loose parts or screws.
* There is sign of damage to the outer casing, burn marks or stains.
* Cables are not damaged, crushed or grazed in any way.
* Check the plug to ensure there are no cracks in the casing and that the pins are not bent or damaged in any way.
* Check that wires are attached to the correct terminals and that no bare wires are visible other than at the terminals.
* Terminal screws must be tight.
* Check that the correct fuse is inserted.
* Check that the cable clamp is securely fitted over the outer insulation cable
It is good practice to put a fuse label on the plug detailing the correct fuse value that should be inserted."
