Classification advice please | on ElectriciansForums
Discuss Classification advice please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
lucky1
Hi All,
When doing an EICR we have come across the following. I would suggest these are C1 defects. My colleague thinks C2. Any thoughts would be appreciated. Thanks in advance for your help.
[ElectriciansForums.net] Classification advice please[ElectriciansForums.net] Classification advice please
Exposed terminals within covered enclosures? ..2
As above but covers missing? ..1
Liking the multi-strand Neutral in the D.B Mainswitch
it's tony's turn this week.
Hi All,
Thanks for that,you shouldn't really
My thought was for but a brief instant,nevertheless I accept your appreciation
What size MCB are the circuits protected by in the home-made marshaling box which are a fraction of the size of what I'm assuming is the supply wiring?
It's not ideal but 4 conductors of the same size in an LN breaker usually works ok (assuming that was your issue?)
As for the homemade busbar box, is there a suitable warning on the lid to let you know there are live busbars in there? If there is then I don't see that it is much different to a normal busbar chamber. Or is it that the outgoing cables are longer than the recommended 3mtrs?
Reply to Classification advice please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That is what i am going to do. Thanks mate!
This fella puts his face to it about halfway through, he has an opinion on the very subject.
4K
