Click UK switch fuse | on ElectriciansForums
Discuss Click UK switch fuse in the UK Electrical Forum area at ElectriciansForums.net
newfutile
Nearly Esteemed
Supporter
hemel hempstead
How would others code the switch fuse not meeting IP4X on the top surface?
The live terminals are very close to the top edge
[ElectriciansForums.net] Click UK switch fuse
These kind of nibble outs have always naff and normally nearly always leave a gap around the cable entry. Most sparks will squidge a bunch of mastic around the gaps but it still looks rubbish
It's in a communal cupboard what if someone put there car keys there while checking the meter? Is silicon conductive before it dries.
ip4x is a 1mm piece of wire,ip2x refers to a bs finger
Or decided to take their metal knitting needles in there. I was trying to make a sensible risk assessment.
Silicone is not conductive snd - in any case - why touch it while it’s wet?
But we are now talking about resolution of the issue. I thought you were doing an EICR?
Reply to Click UK switch fuse in the UK Electrical Forum area at ElectriciansForums.net
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
