Close coupled seal for 2" flush with 100mm OD? I'm trying to locate a close coupled cistern seal (foam or rubber) for a 2" flush with a 100mm OD and 67mm ID. All I can find is 105mm, 107, or 110mm OD.
The pan recess for the seal will only accept 100mm OD.
Any ideas on where I could go?
Close coupled seal for 2" flush with 100mm OD? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
