Discuss Closet door jamb switch in the UK Electrical Forum area at ElectriciansForums.net
Wire both bulbs in parallel. Wire both switches in parallel. Wire each of those in series just as you would simply wire one bulb in series with one switch if you were doing a simple circuit for one door.
Hope that makes sense without a schematic!
Thank you - just installed the switches as you described and they work perfectly, just like I wanted. Much obliged.Wire both bulbs in parallel. Wire both switches in parallel. Wire each of those in series just as you would simply wire one bulb in series with one switch if you were doing a simple circuit for one door.
Reply to Closet door jamb switch in the UK Electrical Forum area at ElectriciansForums.net
