Coax CT100... | on ElectriciansForums
Discuss Coax CT100... in the Electrical Tools and Products area at ElectriciansForums.net
SEC-Tom
Which is the best stripping tool for this?
Im kinda lazy and have been using a stanley knife and tail cutters to do it usually...
Have seen certain things on eBay but im still unsure. Must be for the CT100 coax...
Many thanks Tom.
I've got both the Cyclops and the Televes. Both are good.
The Cyclops is good for Cat5 and Flex.
The Televes strips the outer sheath and the dielectric of coax at the same time using 2 blades. You line the end of the coax up with the edge of the tool and it takes off just the right amount of each.
the blade runners ok for occasional use n smaller than 4mm swa otherwise good old Stanley n Bacho as for coax the thing Lenny linked to is ace n doesnt cost the earth either Maplin have similar TOM probbly got a specific one for ct100 m8
Reply to Coax CT100... in the Electrical Tools and Products area at ElectriciansForums.net
Take your photo on phone. Screenshot it to replicate it, then crop out the excess screen. Brings the image file down to a reasonable size. Was...
