Coax help | on ElectriciansForums
Discuss Coax help in the UK Electrical Forum area at ElectriciansForums.net
London
Wanting a hardwired coax for my tv, I already have a tv coax point but I want to keep this and don’t want any cables on show, now would the best way be run a Coax into the wall into the existing coax point would I need to add a splitter inside the coax point for the new coax?
I have existing coax point, now I’m going to run a coax from tv on wall through a brushed outlet now can I run the cable will be fixed inside stud wall into the existing coax point and join it inside the back box with a splitter?
Just run that by me one more time?
There will be a coax from the TV to the wall?
So that's a cable on show...
Reply to Coax help in the UK Electrical Forum area at ElectriciansForums.net
well now to throw some stuff on the tv wiring I did ages ago I have a labgear 8 port distribution amplifier mounted in the airing cupboard...
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
