Hello All,
This is my first post as I'm a new member so please be gentle
I am in the process of renovating my house and have run in two coax points (x1 for freeview and x1 spare) to each room from underneath the stairs, which is where I'd like all the coms equipment to be located. I thought I could have a splitter here and run a 'feed' to the loft for the aerial connection.
However I am bit concerned by some of the threads I am reading in terms of where they should be run to, as the cables are already installed. I read a thread where someone said all cables should be run directly to the aerial…
The loft eventually will be converted to a bedroom so I wasn't keen on having any equipment in there and have everything under the stairs
Any advice would be greatly appreciated
