Hi all… just after some independent opinions…
I have a VM install with 4 units in one building.
The VM the engineer ran one cable from the street to the basement. He then installed a 2 way passive splitter : one output for one unit and then the other output into a cupboard.
In the cupboard he installed a three way passive splitter for each flat.
He then said that he couldn’t get a signal in the three flats (the first unit was OK).
Is it OK to have:
Just one cable from the street to four independent units?
To install two splitters in series?
By my calc the first splitter reduces signal strength to half and the second to one third so each flat sees one one sixth of the signal.
Should he have ran a cable into the cupboard and used a 4 way splitter or ran four cables into the cupboard?
Any opinions appreciated
Is it OK to have:
