Falcon (Rangemaster) continental induction range 10 yrs old. Tried swapping out control indicator unit pcb (shows the knob settings) with identical pcb to try to correct a control fault. Get er31 code which I think is a configuration issue. Only got knobs, no buttons. How to configure? No jumper on board. Tried correct pan on ring - no change.
Control issue is that the 2 LH rings often won't turn down power despite showing correct lower setting. Moving pan can trigger the lower setting to act. Thanks.
