Code help | on ElectriciansForums
Discuss Code help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
llywelyn111
Hi,
A cooker control is located 400mm above a hob, to the left had side. Is this a code 2?
Also the DB is in a cupboard above the hob and extractor. Do I just cry? here where the tails and earth come in, meter and cut out outside. I love 1960's wiring.
no sign of heat damage at all so happy with that. I was thinking that code 2 would be very harsh. As it's not directly behind the hob at socket height
Reply to Code help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
The power company only brings in 3 wires which is 2 live and 1 neutral wire. It’s our responsibility to add the ground rod to bond the neutral...
