Code query | on ElectriciansForums
Discuss Code query in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
graham123
TT install. 100a main switch. No 30ma rcd protection for socket outlets. C2 for sockets that can be used outside. But is is a C2 for all socket outlets regardless as no 30ma?
C3 unless socket is in bath/shower location. Here's ESC best practice guide:
http://www.----------------------------/mediafile/100404922/Best-Practice-Guide-4-Issue-4.pdf
Reply to Code query in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I would probably C3 it, based on no contact with sharp edges, all the terminations being tight, and no signs of any thermal damage. With all...
Usually if there are only C3 observations it would usually be deemed satisfactory but could be found to be unsatisfactory in unusual...
davesparks
