Code question PIR? | on ElectriciansForums
Discuss Code question PIR? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Danielwareham
A PVC cable that runs from the house to a shed clipped on a wall to a metel clad socket in shed? No conduit.
BS 7671-2008 code 2 requieres improvement , code 3 requieres further investigation.
By Big green book is in van and its cold outside so i will get back to you on the Condition report deffinitions.
c3 improvement recomended ,
c2 potentially dangerous,urgent remedial action required,
c1 danger present, risk of injury, immediate remidial action required
Electrical installation condition report.
Reply to Code question PIR? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
BTW, the LD at the house will be 1" to accommodate the 6/3 coming from the house. Will use a 1" to 3/4" adapter to neck down to the 3/4" conduit...
