Coding on eicr | on ElectriciansForums
Discuss Coding on eicr in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
albi
north east england
Hello every one not been for a while so my apologies.
To my question I have rows of switch start fluro's all wired in T&E. The cable runs through the fitting bast the ballast with no heat protection, so am I right in saying it would be a code C3
Should be run under some heat shielding.
Have seen an IP64 fitting catch light because the cables were run above the ballast.
I would C3 it probably. Possibly C2 if it was badly discoloured and the cable was tightish against the choke. Hard to say without being there.
Is this an office? Are lights on for prolonged periods. I have one customer that insists on leaving a floro switched on 24/7. I check it every year as the internals all tend to go a bit brittle and knacked..
Reply to Coding on eicr in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
i notice you mention "fire rated" instead of "metallic" Are we talking about a metal consumer unit? I know its presumed... but just checking
I would C2 this, cable is not suitable for the environment its installed in, we would C2 a socket for equipment likely to be used outside , cable...
