coffee machine plug burned- what to do? | on ElectriciansForums
Discuss coffee machine plug burned- what to do? in the Electrical Appliances Forum area at ElectriciansForums.net
AJ16
When our coffee machine was switched on this morning the plug started smoking. One prong is burned black at the end where it goes into the wall socket. I'm just wondering what should be done now. Is it just a case of changing the wall socket and cleaning up the prong/fitting a new plug, or should we let De Long know as it's not a year old yet?
[ElectriciansForums.net] coffee machine plug burned- what to do?
As already mentioned replace both the socket and the plug together but also check every other appliance that may have been used in that socket, if any of them have plugs with damaged, burned or even discoloured/tarnished pins, replace those plugs as well. Damaged sockets usually damage all plugs that are used in them and likewise those damaged plugs cause damage to any other sockets they're used in.
Reply to coffee machine plug burned- what to do? in the Electrical Appliances Forum area at ElectriciansForums.net
This UK company seem to sell parts for them so it might be worth contacting them after that you could try the manufacturers La Rocca | Máquinas de...
A crimping tool that is designed for copper terminals, may well not put enough pressure on the terminal to hold the cable correctly if used with...
