Cold water flowing back into hot feed. Hi, I'd be grateful for some advice please. Every 12- 18 months I have a problem with cold water flowing back into the hot water feed through a shower mixer cartridge, causing all hot water feeds to run tepid or cold. Replacing the mixer cartridge fixes the problem, but only for a while.
Would a better solution be to have a water pressure regulator installed to reduce the pressure of the mains cold water? Are there any negative aspects to having a pressure regulator installed?
Many thanks in advance
Cold water flowing back into hot feed. to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
