I would just like any comments if this seems OK.I have a rewire/new install to do on the above which is a second floor with about 8 rooms to have its own cu and they want a small kitchen at each end with a hob and oven also two power points in each room and lighting,no electric showers or anything else.The main cu on ground floor is 3 phase mostly supplying a large kitchen with 3 phase equipment and power points.I am thinking of using 3 phase,one each for the ovens and hobs and one for lights and power as I don't think there is a lot of spare capacity and to fit a single 60A mcb supplying that one floor cu seems a bit of an imbalance.The present set up is a single one phase 32A mcb supplies that floor cu which is an old 3036 Wylex with fuses for rings and lighting.Thanks.
