Anyone ever put in any of their lights such as the GL016's they look like they're wired in series through the joint boxes but just trying to work out if any old adaptable IP rated boxes could be used rather than buying collingwood own made JB2's or JB4's at a higher cost. Customer had some fitted before in paving blocks and says he had prev electrician run jb to jb in swa but thinking might be a pain trying to fit multiple jb's under ground using swa between them if plastic boxes and he wants magic gel as used last time. Costly stuff by the looks of it !
