hello
i guess this will work and i will explain as best as i can )
new build with ideal combi boiler with basic normal wiring L/N/E with stat link
they have installed two zone vales
one for the front room rads
and one for the rest of the house
i have been given two honeywell wirless roomstats
my thoughts are as follows :
wire the wireless units in the normall way with both of them across the stat terminals , if either room calls for heat the apropriate reciver will close and alow the boiler to run. my problem is getting the apropriate zone valve to open .
i guess that i would wire the brown of the valve (from memory) to the switched side of the receiver so that it opens with the right roomstat?
hope my ramblings make sense , its just it seems a little unusual to me ?
regards
regards
