combi boiler wiring help | on ElectriciansForums
Discuss combi boiler wiring help in the Australia area at ElectriciansForums.net
mcm
can anyone please help with the wiring of a combi boiler that is to be moved into loft space using old programmer and wireless room stat.
as not done much boiler work not sure how to wire this, i have wired combies in the past but straight forward such as L,N,E from spur to boiler and then a room stat but never with a programmer controlling the CH.
I thought of this but not sure.
L,N,E from spur to boiler.
L,N,E from boiler to programmer.
CH outgoing from programmer to room stat receiver with perminant L,N,E
from outgoing of receiver to SL on boiler.
Not sure if this correct as in the past the combies have always had a live to room stat and return side on boiler that is normally got a link in. so does the boiler need the same or is above ok?
thanks
no as not a combi at the min. plumber taking old system out that has cylindar and valves to replaced with a combi sorry should of made it clearer.
Reply to combi boiler wiring help in the Australia area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
Electrician Boiler Fault Boiler Fault I’m hoping someone can help with this boiler problem. Couple have just moved into a house that has a Grant...
