Combi boiler | on ElectriciansForums
Discuss Combi boiler in the Talk Electrician area at ElectriciansForums.net
E
ed-ectrician
I'm a bit of a novice when it comes to boilers. I need to wire up a combi so no s or y plan to worry about. It has a faulty external control/programmer. Is it as simple to wire as 3a fused spur to control to boiler flex? Can i use any controller? Which one should i ask for?! Are they easy to wire up? L-n-e in and out? Easy as that?!
Thank you VERY much
Ed
On a Combi boiler you only need to control the central heating as Hot water is on demand.
A single channel programmer achieves this and is usualy connected across 2 terminals in the boiler totaly seperate from the mains in. So you have a mains 3 core supply from a 3A switch fused spur (as i was informed gas safe regs require double pole switching) and a seperate flex to the programmer fed from the boiler (not the sfs).
Quite often around here people use those remote programmable room stats as the programmer.....reciever unit is mounted close to the boiler and wired up and programmable roomstat (which is battery powered) can be anywhere in the house.
Same really , I use Grasslin or Honeywell programmers though , if that helps . Piece of cake to do. Geordiespark will tell you all you want to know about boilers for a couple of bottles of brown lol.
Definitely worth getting the remote style programmer/stat, as Swicade says. Costs a bit more to buy, but great flexibility and a doddle to install the base. Just make sure you get the correct unit for your boiler.
Love the honeywell CMT 927 - not the cheapest but very reliable and gives a nice constant temp in the house but ramping down the boiler when nearing temp but not stopping it.
Aye ..... Aahhv messed aboot wi' a few dodgy boilers in me time, but aahhv gorra Tidy one noo. :)
I have fitted lots hard wired and wireless
when the lecky goes off with wireless some people don't know how to sync them back up can be a pain with revisits
According to pg8 of this i need a l n and e from dp spur, to controller then l and n to boiler then 2 switched lives from boiler to controller. Where does 3 core come in? Are u saying use all four conductors in threecore cable (sleeved as lives) and run 3 core from boiler to controller then?
Wouldnt that 3(4) core have to be butyl cable or similar?
Bleaurgh
http://www.plumbnation.co.uk/site/h.../honeywell-cmt927-technical-specification.pdf
Wtf
from spur to programmer LNE from programmer to boiler 5 core flex heat resistant from programmer also 3core &earth to statt (simples)
Reply to Combi boiler in the Talk Electrician area at ElectriciansForums.net
I cannot give the answer. that said if you google it and download the PDF it may give you the answer.
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
