Combining Two 12v DC PSU Outputs for 24v | on ElectriciansForums
Guest viewing is limited
Discuss Combining Two 12v DC PSU Outputs for 24v in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Gloucester
I have a 9 output CCTV PSU wall mounted supply. I have several spare outputs and need to run a maglock rated at 24v DC 250ma. Each output on the PSU is rated at 12v DV 2A.
Can I link two outputs in series to output 24v DC?
I imagine that all the negatives are linked (and probably the positives too), so linking two outputs would just cause it to go pop.
That's what I feared might happen which is why I haven't tried it yet!
Each output is protected by it's own resettable PTC so not sure if that would offer any protection from doing any damage by trying it?
You could always do a continuity check (with power off) between the negatives of the DC outputs, but as above they are probably all common to each other.
That's great idea. I'll try that but it looks like I'll be buying a new PSU for this. I was just hoping to use the battery backup for the maglock but it's not a security issue so not essential.
If you only want 250mA output then another option could be to use a boost converter... loads for sale on Ebay... They're not super efficient, but you've got 2A output to play with and it's mains powered, so no worries there.
Another good suggestion, many thanks. Never even thought that was an option. So would this also work on battery backup? I assume so as the input to the booster is from the output on the PSU which remains powered during battery backup. I assume this would drain the backup battery quicker though.
another option is to search out an old fire alarm panel that a local installer has replaced and is scrapping. most have 24V PSU inside, with back up batteries. saves polar bears also.
You are definitely a scouser !
and bloody proud of it. :p :p :p . joking aside. i'm like my dad up to a point, but i don't straighten rusty nails or make wall plugs out of bits of scrap wood like he did. he even made his own buckle clips from tin cans, cut out with snips.
Reply to Combining Two 12v DC PSU Outputs for 24v in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
