combi's | on ElectriciansForums
Discuss combi's in the Australia area at ElectriciansForums.net
W
wannabesparky
would you put a combi boiler on its own circuit via a fused spur? if not could someone please tell me the best way to go about it? thanks.:confused:
As prev replys,no problems with single 2.5 just check what pd rating is and make sure you use a 3a fuse in your spur or it will lunch the boilers pcb if theres ever a fault.
Reply to combi's in the Australia area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
This is an RSS feed of thread: Vaillant Sustain 28kw Combi Heat Input Content of the thread: Could anyone tell me whether the Vaillant Sustain...
