M
Modernelectric
Hello folks, hope you are well.
I was recently called out to investigate a problem with a "Jordao mural fundador slim"
Fundador Plus MSlimk
everything is working EXCEPT the under unit fluorescent light fitting, which is showing 0 volts when the switch is on. The fridge is controlled by a digital display panel, and in my opinion it is probably faulty. If anyone has worked on anything similar to this i would be interested to hear your thoughts.
Thanks.
Martin.
Thanks.
Martin.
