Commercial lighting arrangements/advice | on ElectriciansForums
Discuss Commercial lighting arrangements/advice in the Commercial Electrical Advice area at ElectriciansForums.net
Glasgow
ive not really worked too much on commercial installations so i thought id post this and see if i can aquire some useful info.
Client wants :
-light installed in a multi-suite space rental type deal
-there is a suspended ceiling in every suite. It is not the standard 600x600 panels that i am used to though.
Im thinking of running in a plug in lighting greg system, with around 160 spot lights.
Is this a good idea or should i opt for bigger lights?
Any suggestions would be appreciated, operating slightly outside my usual area
I personally wouldn't go with spot lights. LED panels are commonly employed now, what size are the grid panels.
yeah im seeing 1200x 600 panels, that might be the one, i'll need to nip back down to it tomorrow have a wee check.
Is the greg sytem the way to go?
What about the earthing? should the metal frame of the suspended cieling be earthed? if so, is there a particular clamp to fix an earth onto it?
You'd be there all wek ensuring every part had a good bonding connection!
Just watch the inrush current; subdivide your circuits as much as reasonably practical.
Edit..Oops, misread your post, thought you were installing 160 led panels!
Reply to Commercial lighting arrangements/advice in the Commercial Electrical Advice area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
