commercial Roofers | on ElectriciansForums
Discuss commercial Roofers in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
W
woko
Can anybody recommend a commercial roofing company in derby/notts area?
Looking at subbing a large cement board install out. 40 kw 160 panels.
Cheers
Reply to commercial Roofers in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
