I own two flats with a small common lobby. Although operable from both flats, the common lobby light appears to be wired to flat A's circuit. Rather than fit a landlord's common area meter and circuit, I am thinking of having flat B's lobby switch professionally disconnected from A's circuit and then have an additional light fitted in the lobby but wired on flat B's own circuit. I would also have both lobby lights low powered and time switch activated as part of the work.
For the sake of one light, Is this an acceptable way to overcome an otherwise costly installation of a landlord's meter from the utility supplier plus additional circuitry?
