common departures and codes | on ElectriciansForums
Discuss common departures and codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
Tapouchoke
Hi all topic for chat
just wanted to ask if anyone had a list of common departures and codes??
I had one a few years ago but have missed paced it
Apart from the obvious ones socket outlet in swimming pool :p lol
You may find some of the esc/nic coding and the recomended coding conclusions a little puzzling
A Code 2 being unsatisfactory in their eyes :eek:
They are comprehensive,and with a pinch of real world salt mixed in they may be handy
I have to say that I agree with them, surely if something requires improvement then it can't be satisfactory can it?
That's a judgement call for the Inspector.
If something requires further investigation how can you be sure that it's satisfactory?
Surely he's already made his judgement call saying that it requires improvement? Therefore to be satisfactory, has to be put right. No?
You can't be sure it's satisfactory, which is why code 3's are very much a judgement call.
What the ESC are trying to get round to people is that code 1's should be for immediate danger, live metalwork, no earthing, big holes you can stick your fingers onto live parts through etc. Code 2's are for things that aren't gonna bite you on the bum right now, but have the chance to given the right circumstances, and should be rectified. They feel that in the event of a code 1 then an electrical danger notification should be issued, and I agree with them, as I'm sure when they all put their heads together their knowledge is a lot better than all of us on here. Also, all the big schemes had a hand in the BPG4, so it can't even be seem as another one of the NICEIC rip-offs....
It doesn't matter much about codes now anyway, as the whole PIR process is being overhauled in the first amendment.
IEE guidance simply states that it would not be reasonable to consider an installation with Code 1 deviations to be in a satisfactory state. As they write the Regulations, it is my opinion that a Code 2 deviation could still result in a satisfactory outcome at the discretion of the Inspector. Therefore I do not feel bound by NICEIC advice (unless I was carrying out a Periodic Inspection for an NICEIC company - in this instance obviously I would have to consider their advice).
Different strokes for different folks!
I think the fact that the ESC have the given the guidance they have helps no end, as I've had to argue the ---- with enough people on my thoughts on coding, so now there is a standard I can use that for ammo.
But each to their own! :)
This arrived at my door from a mate in London who's just had a PIR done and he's asked me to have a look at it. Anyone see anything they disagree with?......... I do. I'm sure 16) is a bit fishy, and bearing in mind it's 25 years old i'd find it hard to give it a code 2 for not having an rcd.
I've just shrunk it a bit!
[ElectriciansForums.net] common departures and codes
I was thinking more like it's fine to have a 230v fan in zone 1.
Only if it has an adequate IP rating plus all circuits in a room containing bath/shower require RCD protection. Supplementary bonding was inadequate also according to report.
indeed!:D
This then throws up an interesting debate. If the fan has been installed after the original installation but before it was deemed necessary to have an RCD in a bathroom, should an RCD be fitted retrospectively?
I'm genuinely asking here because you chaps have far more experience than me.
*edit*
I'll grant you that if no rcd is present then the sup bonding better be up to scratch, I told my mate as much.
*another edit*
just wondering then if it's only ok to have a 230v fan in zone 1 IF you have an RCD protecting the circuit which feeds the bathroom.....
you know what, it seems like the more I learn, the more there is to know!
Reply to common departures and codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It’s difficult to advise on an electrical issue when some isn’t very conversant with electrical terminology.
