darklink
Hello All
First time on a forum. I need some help!
I've wired up a block of flats communal lighting. very basic lighting
a 3core and earth from the board to the first light then from that the 2nd to 3rd then it stops then from the board a 3 core and earth to the first switch then second then third then it stops
all the lights are emergency fittings hence the 3core.
I was originally going to use a timer breaker but found these neat little sensor switches (no neutral needed, but I have one available) and for some reason the lights wont turn off.
I disconnected all the switches and blocked them through and they still stay on.
I'm getting 50v off the switch wire with the light on.
any suggestions
Pete
any suggestions
Pete
