Communal Lighting | on ElectriciansForums
Discuss Communal Lighting in the UK Electrical Forum area at ElectriciansForums.net
Reply to Communal Lighting in the UK Electrical Forum area at ElectriciansForums.net
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
I would think that if they are apartments, and not something like uni halls with private bedroom and communal facilities, then each one would be...
