B
Big_Nige
Following on from my questions about DIN rail terminals, I've decided that the best approach would be to replace all of them and install a small Consumer Unit on the boat. At the same time I will move the main breaker off the DIN rail and into the CU. I need room for 8 modules in total, but to allow for future expansion (the circuits are radial) I want to try and get a 12 module CU - if I can get one to fit!
So my requirements are for a compact 12 module CU with a top-hat DIN rail, ideally rated at IP55 or higher. This one looks promising (link), any other suggestions?
