Comparing Testers | on ElectriciansForums
Discuss Comparing Testers in the Electrical Tools and Products area at ElectriciansForums.net
timhoward
Broke Internet
Supporter
Solutions
Oswestry
While I have more testers of various ages that I know what to do with, I don't have anything that does a 2 wire no-trip loop test.
Normally this doesn't bother me as in the past I've observed such tests are unreliable and rarely repeatable.
The other day I had a commercial testing job with lots of grid light switches where it would have been rather handy. (Or at least quicker)
I'm vaguely toying with getting a newer tester that has this test.
I'm aware that the following have this feature:
Megger 17x1
Kewtech KT66DL
Later Megger LTW testers.
Are there other testers out there that do a 2 wire no trip loop? e.g. do any Fluke testers?
Don't worry, I'll very rarely use it!
Can you just get a spare set of leads and cut and rejoin the NandE together ?
I'm fairly sure that would trip RCD instantly, as part of the 3 wire no-trip test is a higher current L-N test, at least that is true on the 15xx series.
I have an old Robin EFLI tester and Im sure you can EFLI test at switches by putting the earth lead and N to the back of the box without it banging out an RCD. It has the old D lock which pulses / blinds the RCD iirc
Reply to Comparing Testers in the Electrical Tools and Products area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
Can you show me one that you'd buy... a new one. Cheaper one.
