Discuss Compatible mcb for Hager 3871 in the UK Electrical Forum area at ElectriciansForums.net
Thanks Westward so assume also then that any Hager rcd main switch will also be compatible?Any Hager mcb will fit that board however it has a non compatible main switch fitted in the first place plus another mcb which shouldn't be there. Personally I would be recommending it is replaced unless it can be returned to the original specification of the manufacturer.
Thanks Bill i did find a previous post which did suggest that these type were incompatible with the newer ones.I think you may find if it is the early Hager breaker with slotted screws the later ones don’t fit, you can normally find them on an auction site.
The Wylex must go or replace the lot
I have spares of those. Will check later for a 50A for you
No problem Rich thanks for checking. Seems like the 50 amps are like gold dustView attachment 59558
Sorry I only have 6 and 32A ones left
Thanks Andy I think i have no choice but to take punt on them and get new rcd main switch as well. Failing that customer will have no choice but new boardThe new ones fit. You don't need to source a 3871.
Reply to Compatible mcb for Hager 3871 in the UK Electrical Forum area at ElectriciansForums.net
