Leesparkykent
Nearly Esteemed
Discuss Complete shambles. in the UK Electrical Forum area at ElectriciansForums.net
Its your end ...if you open your paint software load the pic and save it, it usually loads the right way up..have this issue myself, are you using a galaxy phone by any chance.
No I'm on an IPad so don't really know how to turn it around, well annoying!
Went to survey a job for a pv install today and came across this mess lol.
edit: don't know why the photo loaded upside down, could one of the mods turn it round please if poss.
That is bad but you must have seen the like of it before.
Out of interest, where are you going to connect the PV array in?
Well at least there are only 6 ? circuits and I see there's no seal on the Henley block.
Looks pretty standard for the time it was done, 60's?
Its when someone calls you and says they need a new consumer unit, you turn up and find that, I always start scratching my head thinking why are things never straight forward! It should be easy enough on this to tidy up if thats what you are doing, I think there's more chance of faults on the circuits that a problem mounting a new board.
Yes definitely seen the likes of this before. I think what got me was the customers attitude towards it when I said it needs replacing/tidying up I got the typical "it's been fine all the time I've lived here and I've been here 26 years". I've priced it to replace the lot with a high integrity board and will put the PV on a 16 A mcb or rcbo depending on installation method on the main switch side. Tbh I probably won't even get the job as no doubt some other firm will go in and price just to install a sub board off the Henley block that is there and I got the feeling off the customer that only the cheapest will do.
Reply to Complete shambles. in the UK Electrical Forum area at ElectriciansForums.net
