Completing electrical certificates | on ElectriciansForums
Discuss Completing electrical certificates in the UK Electrical Forum area at ElectriciansForums.net
tomodo
United Kingdom
Hi all, question on testing and completing certificates inside a large factory in maintenance, a lot of the 3P boards here are full of cables, when we are adding to existing circuits, it would be required to perform the necessary tests, R1 R2 and Zs for instance inside the boards, how do we go about this when we are unable to isolate the board, having to open up an old board rammed with cables opens up risks itself. Is there anyway around this or must we be disconnecting from the earth bar every time we work on the circuit. Thanks
Reply to Completing electrical certificates in the UK Electrical Forum area at ElectriciansForums.net
If no-one is able to take responsibility for the installation then it would seem that there is an issue with the company's processes. Someone...
Here the BPG#4 is useful, it is not a statutory document at all, but it provides good guidance as to what can reasonably considered as C1/C2/C3...
