W
whitebeetle
Hi All,
Just wondering how you manage to comply with current regs when adding to an existing older installation.
For example if asked to wire a supply into a garage and the customer has the old type rewirable fusebox do you have to explain that they will need either RCBO Protection/ new consumer unit in order to comply ? Obviously this increases cost dramatically and could price you out of the job compared to the cowboy who'll just wire them straight in on a rewirable fuse !
What happens if the work you do complies but the rest of the installation doesn't i.e if you were to put the garage supply on RCD/RCBO but leave the rest of the property running on rewirable fuses - how much are you responsible for the total installation after you have added to or extended a circuit ?
After modifying a circuit are you totally responsible for the total installation - whats your opinions on this because i'm sure its a dilemma for many
Chris.
Chris.
