Component Din Rail Terminal | on ElectriciansForums
Discuss Component Din Rail Terminal in the Electrical Tools and Products area at ElectriciansForums.net
WallaceP
Here
Hello, I am looking to get some din rail terminals what I can put a 500 Ohm Resistor in. In the past I have used ones like in the photo attached, I cant seem to find them online now. Can anyone tell me the correct term to find them on RS or any other supplier. Thanks
[ElectriciansForums.net] Component Din Rail Terminal
Thanks mate, I wasn't sure if the Diode that comes with this is removable tho.
I assumed they were, but didn’t read the info fully, wago ones are changeable, certainly if you get the right one, see link once a mod has approved it or google wago pluggable diode/led module ( also takes resistors,) there’s also fixed block version but not sure about that as it has other stuff built in
Reply to Component Din Rail Terminal in the Electrical Tools and Products area at ElectriciansForums.net
The terminals in the picture look like the ones Europa components supply, and somewhat less than RS prices
davesparks
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
