Compound mitre saw. | on ElectriciansForums
Discuss Compound mitre saw. in the Electrical Tools and Products area at ElectriciansForums.net
ferg
Patron
N.W.Scotland
It's not really an electrical question but I'm struggling to find unbiased reviews.
I'm looking to get a decent sliding compound mitre saw for personal use.
Woodworking is a hobby of mine and I also have a bit of renovation work to do in the house.
I have in mind this one Makita LS1018LN
I'm a bit of a Dewalt fanboy but this seems to match my needs better.
My main priorities are accuracy and reliability.
Does anyone have any experience of these saws or alternative recommendations?
Cheers. :)
We've got an evolution compound mitre saw in the workshop, we chose that one because it cuts wood, metal, plastic etc.
It's a bit of a 'jack of all, master of none' kind of thing as it's not quite perfect at anything but good enough for most of what we do.
A friend of mine has one of those , he has had it about 15 years plus.
I replaced the motor for him about 10 years ago and it has never missed a beat since.
The original motor failed because of unusual abuse on a rushed job.
The main issue for me was how the rails go backwards on the sliding part of the saw head. It inhibits fitting the saw to a bench when there is a wall behind the saw and close by.
I had the big Dewalt 305mm unit and it was very heavy if you had to move it around.
I had looked at a Space saving Dewalt one for that reason and also the similar Makita but I'm having a bit of difficulty justifying the cost.
Accuracy will often be reflected in the effort put in to setting the saw up.
If you take the time to square it up, or tune it to whatever angle you need then you'll get more accurate cuts than if you just trust to the protractor markings on the tool.
Judge that on how many times you wished you had one, and the times you have been dissatisfied with the results of your alternative substitute.
Absolutely. I had to do this with my last saw but the accuracy was terrible when using the sliding function and the head would move slightly if I didn't pay attention when cutting.
[automerge]1590164200[/automerge]
There is also the fact that if I spend too much on the saw I might end up keeping it company overnight... :D :D
I think it's Lewden and they are cheap in Englandshire.
I can't get them from Wholesalers and have seen them only once, jammed in to a crappy proteus board.
I stick to Hager but as they are a good bit dearer customers always go for the Dual board.
Tut, tut...
"signable off"???
signoffable, surely...
I’m going to get the large kapex as soon as I can slip it past the boss!
I've had the Bosch GSM8SJL for a few years now. Cracking single bevel mitre saw for the price with great cut length.
Mitre saws are more likely to stay accurate if they are not lugged about in and out of vans a lot. Mine has been lugged about a lot and is still sufficiently accurate.
Reply to Compound mitre saw. in the Electrical Tools and Products area at ElectriciansForums.net
