Concealing TV cables in wall | on ElectriciansForums
Discuss Concealing TV cables in wall in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all
What's everyone's preferred method for concealing cables in the wall for mounted TV.?
I am going to install a double socket, 2 x hdmi and 1 x aerial for several TVs to be mounted on the wall.
Previously I used PVC conduit but when an HDMI cable failed, it was a nightmare pulling a new one in as there were 2 bends.
Obviously the socket is not a problem, just the aerial and HDMIs.
Conduit, trunking?
Ideals appreciated
use waste pipe, then use a fastfix box with one of the front plates with a brush on
[ElectriciansForums.net] Concealing TV cables in wall
go for the biggest pipe you can in the wall
Have done exactly the same and is a good solution. There is also room to bring new cables in this way in the future. I would run the power cable to the socket externally to the conduit/waste though.
What about using CAT5E/CAT6 cables and using HDMI converters? I use them for all my new houses.Fit a patch panel and have CAT5E to all Television points, Local source points and Data/Phone points. Any point can then be patched as a Data point, phone point, HDMI point etc. They will easily fit up a conduit, you can cut the to whatever size you require and they dont damage as easily as the HDMI's
Sounds good!
Do you have a link to the products required please?
Yes i do. my usual set up in that situation is 3 cat 5's from patch panel to t.v. point (1 for ethernet on smart tv, 2 spare for central distribution) 3 cat 5's from patch panel to local source point (for ethernet, phone or central HDMI distribution) and 1 cat 5 from tv direct to local source point to link the tv and sky box.
Generally with my installs the sky box is located in the patch panel, so is the t.v. distribution unit, satellite mutiswitch, broadband router, main telephone point, central blu-ray player and cctv system. This allows for easy distribution throughout the house. I mostly do 1 off homes in the countryside though.
I try not to position in the loft if possible. I prefer to use a floor to ceiling cupboard in the utility room. In this i put my Consumer Unit, Fire Alarm panel, Burglar Alarm Panel and Patch panel and have everything centralised and easily accessible
Reply to Concealing TV cables in wall in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
