Concealing unused sockets | on ElectriciansForums
Discuss Concealing unused sockets in the The Welcome Forum area at ElectriciansForums.net
O
oldsparky99
This is my first post on the Forum and I have a question regarding concealing unused sockets. The house I am working in is having a new kichen installed. The existing kichen sockets are part of the single house ring (1978 4 bed detatched). Additional kichen appliances will be installed so I want to take the oppertunity to reduce the load on the ring by wiring new ktchen sockets on a 4mm radial and cease using the existing sockets.
I don't want to replace the wiring on the existing ring sockets so I propose to join the cables and in some way conceal where the sockets have been. I have considered using Wagobox junction boxes and plastering over them but would appreciate any suggestions or thoughts on this.
Welcome to Electricians Forum | Electrical Advice Forum | An electrical forum for electricians in the UK!
Hi oldsparky99 and welcome to electriciansforums.net!
i would use blanking plates if you plaster over sockets how can you do a pir ?? or check for loose connections or if fault came up later on ???
Hi and welcome pleased you joined us. If you post questions on the main forum you will get a better response not everyone looks here.
Chris
Hello, I think you are right to take the opportunity to separate the kitchen onto new ring, but if it were me I wouldn't leave the old wire and sockets in I would try and find the 2 legs of the ring and connect together leaving kitchen totally isolated and avoiding any potential problems.
its gotta come out mate really- you would be leaving live wires in a wall with no clue that they were there, i.e a socket or something and therfore you would have no defence when someone gets hurt by hitting in a nail, as it wouldnt be possible for the customer to work out from the wiring zones where NOT to put a screw/ nail in etc. not viewed all the posts but take the wires out of circuit then just fill with plaster.
Quite right, the old ring wiring has got to be removed, what was I thinking? It's the only safe way to do it. Thanks for all the replies.
Reply to Concealing unused sockets in the The Welcome Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Why aren't you asking them?
