Concrete subfloor leveling issue Discussion Thread | on ElectriciansForums
  • Thread starter Cat213
  • Start date
  • Replies 0
  • Views 108
Discuss Concrete subfloor leveling issue Discussion Thread in the Tilers Forums - UK Tiling Forum. area at ElectriciansForums.net
Hi -
I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and instead of using mortar to even out any glue that was stuck on or sand off, I used a thin layer of self leveler. I mixed it correctly but for some reason still wasn’t level so I tried grinding it with an angle grinder attachment. Made it worse. Poured again. Also made it worse.
I ripped out the existing vanity as seen in the image and there’s now 1/4 inch from vanity bottom to new subfloor with concrete.
My question is:
If I try to fix one last time, should I try to sand down to Original subfloor and hopefully attach whatever I’m using to a shop vac for dust?
Do I do another pour to level up to the 1/4 inch and sand the existing pours down a bit then pour again?
Even with a laser level it’s very hard to tell where slight dips or rigids are so it’s almost impossible for me to sand my hand down to flat,
Other option… should I just hire someone for this? And how much do you think it would cost? (Trying to save $)
Concrete subfloor leveling issue for the Original Article on Tiling Advice Forum
Reply to Concrete subfloor leveling issue Discussion Thread in the Tilers Forums - UK Tiling Forum. area at ElectriciansForums.net
G
Waterproofing options for new shower room Hi, A newcomer here and thank you to anyone with the patience to read my drivel. I am renovating an...
Givey Tago
G
Tiling On Concrete Blockwork Outdoors hi all just been offered a job tiling an outdoor bar ...the bars walls are made from concrete block (not...
Samb213
