Conduit Compression Glands | on ElectriciansForums
Discuss Conduit Compression Glands in the Electrical Tools and Products area at ElectriciansForums.net
Lincolnshire
Hi All
Where do you guys get your PVC Conduit compression glands from - I.e if you were to wire a pre-wired floodlight?
I've seen some installations where you can just push a gland fitting directly into one of the legs of a 2-way/right angled junction boxes but I've not been lucky enough to find where they can be supplied from.
I usually just use a female adaptor and screw in a compression gland into this, but it increases the profile of the leg sticking out so just thinking that if I can reduce this leg by using a push fit like I have seen it would look better.
Cheers!
i always use a wiska box, adjacent to the floodlight. then supply to box can be SWA, cable in PVC conduit, whatever, then flex from light into box, connected with wagos.
Reply to Conduit Compression Glands in the Electrical Tools and Products area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
