Conduit die set recommendations | on ElectriciansForums
Discuss Conduit die set recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Judd
Liverpool
Hello,
Can anyone recommend a good quality 20/25mm conduit die set? After looking online prices seem to vary quite dramatically. I Want something solid that will serve me for many years to come,
Judd
The stocks or die holders are all pretty much of a muchness.
It’s quality dies and a good cutting grease you need to concentrate on.
Even poor quality dies will last if a good cutting grease is used.
Thanks all for the Input, I did notice the ones on tlc website and would consider the hall dies if I have a good month,
Spin, can you recommend any dies or decent cutting grease?
Rocol is recommended, the new stuff is better then tallow as it aids the cutting and prolongs the life of the die, can also be used for drilling, but if I was threading conduit I'd use tallow as I am an old stick in the mud and have a lump of it at home handy for bacon as well........
Reply to Conduit die set recommendations in the Electrical Tools and Products area at ElectriciansForums.net
