Conduit Support | on ElectriciansForums
Discuss Conduit Support in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Looking for some advice if anyone can help.
I've been asked to install sockets in a new build business unit. The company deals with software imaging - lots of computing power but no machinery, tools, etc.
The place is pretty much a standard build with a number of heavyweight vertical RSJ's cross-hatched with U-shaped, mild steel beams onto which a potential plasterboard wall could be fixed. The client is leaving this open, though, so I was hoping to hole-cut through the steel beams and run a 20mm plastic conduit through from one end to the other in an L-shape from the CU on one wall a total length of around 20m.
I'm running a radial circuit for four twin sockets as they are all being placed on this one run. Trouble is, the regs say that rigid plastic conduit has to be supported at 1.5m intervals for a horizontal run, and there's approx. 2m space between these. So, i'm considering fixing a 3x1/2" wooden plate along the length of the wall on top of the steel uprights and then fixing the conduit to that. Steel conduit or tray are options, but I'm trying to keep the price as keen as I can. Can anyone suggest another method?
Without seeing the install, I think useing a piece wood for the fixings sounds ok. Although, I dont think it would be a big problem if the fixings were every 2m instead of 1.5m.
Jay
Jay
Cheers, Jay.
I'm just a bit concerned that the conduit will be hanging in open air inbetween the uprights; wouldn't be so bad if they were going to be covered in plasterboard, but the customer is leaving the wall open, so there is always the chance that some gormless individual will use the conduit to support themselves while they tie their shoes :-/
Just thought there would be another method?
use steel trunking or steel conduit. and i'd be wary of drilling through structural steel.
That was another concern, Telectrix, but on looking at the structure, the steel isn't really supporting anything; it appears only to provide a support for the fixing of the outer (tin plate) walls, and the (potential) internal plasterboard / composition walls.
On the face of it, though, I think I'll quote for the wooden plate; it'll give me good fixings for both the conduit and the sockets.
It doesn't appear so, Telectrix; The main RSJ's are bolted to cross members which the roof is attached too, the internal steel work is definitely not capable of taking that sort of weight.
Don't forget, the plastic conduits will be heavier with the cables in them and will sag down... Not a good look really.
I'd suggest steel, keep it tidy, it won't flop about when and if it ever gets cleaned either.
Only running 2 x 4mm singles and a cpc but, yeah, it's not a good look is it - and certainly not going to be rigid :-(
What do you suggest, Des?
Almost impossible to say without seeing the place,but if conduit can't be supported,therefore ditto tray
Swa on the floor, or conduit dressed around the pillars,metal trunking will give its own support to an extent,that has sometimes been my own decisions occasionally when some self support was needed
Id' certainly go with galv tube, Plastic may look ok now but give it ten years? The spacings in BS7671 are the maximum spacings and way, I would say plastic should be supported more like every 3' in honesty.
Reply to Conduit Support in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
