Conduit tap & die set | on ElectriciansForums
Discuss Conduit tap & die set in the UK Electrical Forum area at ElectriciansForums.net
pc1966
V.Nearly Esteemed
Dundee
Another general question for folk out there with experience: if buying a tap & die set for metal conduit (20mm / 25mm) are there any to recommend, or any to avoid like the plague?
I've had good service from Armeg dies, also Hall's. It's so long since I had bad ones I can't remember where they came from, probably some no-brand emergency purchase.
It's unusual to get a tap and die set for conduit as a tap will not normally be used in conduit work, usually it is just stocks and dies in a set for conduit threading.
I've got about 4 sets of halls stocks which I think are all older than me, I've tried some of the more modern sets but they all seem light and flimsy by comparison. Armeg were probably the best of the bunch.
i won't be doing any more conduit work and so might be persuaded to sell my set ..Hall stock (not knurled) with both 20mm and 25mm Hall dies. all in perfect condition.
Reply to Conduit tap & die set in the UK Electrical Forum area at ElectriciansForums.net
Received guidance from a logical soul on the Kawie Riders forum: Acc Fuse Block Power to BAT LOAD, install new cable from BAT LINE to AUX + (and)...
