Conduit | on ElectriciansForums
Discuss Conduit in the Electrical Course Trainees Only area at ElectriciansForums.net
Wilson12
Trainee
London
When calculating cable sizes...
When I want runs to be enclosed in conduit or trunking.
The grouping (Cg) makes (it) the cable size very large..
What am I doing wrong when calculating enclosed cable size.
An example would be a radial circuit ran with 4 other thermoplastic cables
In =20/ ca=1/Cg=0.65 /cf=1
It = 33.3 a
Using f6 tabulated ccc
Means I have to use a 10 mm2 cable
Looking at this if I wanted to use 2.5mm2 I can't use more than 1 cable in conduit???
33.3A is well in for 6mm. just borderline for 4mm. also, you need to use Ib for calcs. not In.
Yes ib and in would be the same in this case.
Which reference method did u use in table f6
And it's not possible to do more than one cable in 2.5?
Reply to Conduit in the Electrical Course Trainees Only area at ElectriciansForums.net
