Best I can find is the legislation, -6% and +10% for 230V but I thought they were due to change to +-10%.
Can't find that though.
The electricity supply regulations 1988
State:
30 (2)
For the purposes of this regulation, and unless otherwise agreed by the consumer, the permitted variations are—
(a)a variation not exceeding one per cent above or below the declared frequency; and
(b)a variation not exceeding six per cent above or below the declared voltage at that frequency where that voltage is below 132 kV, and not exceeding 10 per cent above or below the declared voltage where that voltage is 132 kV or above,
or the variation which may have been authorised by the Secretary of State under paragraph (3).
This was amended in 1994 to read:
(2) For the purposes of this regulation, unless otherwise agreed by the consumer, the permitted variations are:
(b)in the case of a low voltage supply, a variation not exceeding ten per cent above or six per cent below the declared voltage at the declared frequency;
(c)in the case of a high voltage supply operating at a voltage below 132 kV, a variation not exceeding six per cent above or below the declared voltage at the declared frequency; and
(d)in the case of a high voltage supply operating at a voltage of 132 kV or above, a variation not exceeding ten per cent above or below the declared voltage at the declared frequency.”
