confused answers:Qs for Caravan - 2382 | on ElectriciansForums
Discuss confused answers:Qs for Caravan - 2382 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
T
tcfreeman08
Hi all,
Just done some samples papaes, the confused Qs are as below:
Q. The minimum cross-sectional area of any conductor in a caravan is
a.1.5mm2
b.2.5
c.4
d.6
the answer is a, however, I found from P.191, the min. is 2.5mm2 for 16A
Q. The maximum permissible height for a caravan inlet is
a.0.5m
b.1
c.1.5
d.1.8m
the answer is d, from P.192, the regualtions shown that the inlet btn 0.5 to 1.5m, in special cases exceed 1.5m, why 1.8m??
help please
Q1 The minimum size is 1.5mm2 for internal caravan wiring, The 2.5mm2 16A requirement is for the flexible cable between the caravan and the mains connection piller
Q2 1.8m is the max permissable height for a caravan mains inlet. as to why, thats what it says in the regs and I can only assume this dates back quite a few years as some older vans have the inlets quite high on the body
HTH
Upvote 0
Reply to confused answers:Qs for Caravan - 2382 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Electrical Courses
