Hey, been to look at a job this evening its not your standard S, Y or Combi system. The plumbers gone in and only changed the boiler but disconnected all the cables to it.
Scenario:
Boiler, with pump above it, basic programmer (HW ON, CH ON)
Then in the airing cupboard theirs one 2port valve and the cylinder stat is a plumbed in one which goes to a stat'ed TRV (little copper wire) No electrics involved.
system does not have a Room stat but does have frost stat.
When speaking to the plumber he couldnt describe what system it was but said
When calling for water valve is closed
When calling for heating valve is open
The wires which are left dangling is:
Feed from FS
3 core (haven't yet investigated where from)
and a flex hanging down from the pump.
The bit which gets me is how can you call for HW when theirs no electronic stat involved? Can anyone work out how it was wired from the cables which are dangling? Nothing else seems to have been touched just those wires that are dangling.
After a busy day fitting PV panels this has got me stumped.
Thanks!
Scenario:
Feed from FS
Thanks!
