Confused, must be missing something simple. | on ElectriciansForums
Discuss Confused, must be missing something simple. in the UK Electrical Forum area at ElectriciansForums.net
vini
Glasgow, East End
A cooker switch with single socket indicated a reverse polarity. It was connected to a double socket into which was plugged a gas hob and gas oven. Double socket also showed reverse polarity. However when the earth prong on the plug was inserted into the socket the LED display on the plug in tester showed as correct. What am I missing?
A professional piece of test equipment and a screw driver to open up the kit to physically see if a problem is present.
A set of City and Guild qualifications I suspect.
Reply to Confused, must be missing something simple. in the UK Electrical Forum area at ElectriciansForums.net
